Power question, ALPINE PDX
Old Apr 1, 2008 | 09:51 PM
RollingRock's Avatar
The subs i have are 2 ohm DVC
The audio head I was talking about was a dude at my office....he said i was getting 600 per sub, i said 300
Old Apr 1, 2008 | 10:13 PM
dB-SPL's Avatar
He needs not to say another word describing 'audio' in any way.
Anyway.. In your case:
(2) DVC-2 drivers can equal either 0.5- or 2-Ohm final loads. So make sure you wire the coils in series and the drivers in parallel because the PDX is not 0.5-Ohm stable.
Old Apr 1, 2008 | 10:33 PM
Low_e_Red's Avatar
Originally Posted by 051fdrof
It is the same amount of current to each speaker in a series or parallel circuit, provided that all of the speakers are the same impedance. Normally the difference is the total amount of current, but the PDX amps have identical 2 Ohm and 4 Ohm specs so they must compensate internally for 2 Ohm loads. They won't give you any extra from bridging, either.
When wiring two speakers in series the impedance of each speaker is added together to come up with the load on the amp.
When wiring in parallel, (assuming both speakers are the same impedance) you divide the speaker impedance by the number of speakers.
(2) 4 Ohm speakers in parallel = 2 Ohm load
(2) 4 Ohm speakers in series = 8 Ohm load
The lower the load on the amp, the higher the current draw. (unless you're a PDX, apparently)
I call BS!
Old Apr 1, 2008 | 10:40 PM
dB-SPL's Avatar
Originally Posted by Low_e_Red
I call BS!
No. He was correct. The Alpine PDX-1.600 was designed to give 600 watts @ 2- AND 4-Ohms. Bridging would bring no gain for two reasons.
a) It does the same power @ both 2 and 4 Ohm loads
b) It only has one channel anyways. There's nothing to bridge!
Old Apr 1, 2008 | 11:18 PM
Bartak1's Avatar
I call BS!
And you ARE correct...........I wasnt for sure myself (pretty much no experience with the PDX amps myself) so I had to look, but I figured they had more output bridged.
Straight from the Alpine website. (4.150 for example)
RMS Power (at 14.4V THD+N,20Hz-20kHz)
• Per channel into 2 ohms : 150W x 4 (<=1%THD+N)
• Per channel into 4 ohms : 150W x 4 (<=1%THD+N)
• Brigded 4 ohms: 300W x 2 (<=1% THD+N)
I assume we (and 051fdrof) is/are talking about the PDX amp in general, and that we are all smart enough to know that you cant bridge a mono anywho....
Just to try to stop this from turning into an "I know more than you" thread, although those can be fun
Old Apr 2, 2008 | 12:15 AM
scottbigred's Avatar
since when cant your bridge a mono amp????
Old Apr 2, 2008 | 12:29 AM
Bartak1's Avatar
Ohh man, did you miss the memo????? They just changed it a few days ago....big red print "THERE SHALL BE NO MORE BRIDGING OF MONO AMPS". Big dissapointment for me I tell ya
Old Apr 2, 2008 | 01:14 AM
Low_e_Red's Avatar
I am up for a I know more thread tho....
Old Apr 2, 2008 | 07:24 AM
051fdrof's Avatar
Okay... I was referring to the fact that you don't gain any more power by bridging the outputs of the (multi-channel) PDX amps. If you look at the specs for a 4.100 you'll see that the bridged output is just the sum of the two bridged channels. It is more output, but no more than using the two channels independently. An MRP-550 on the other hand, gets you 250 watts by bridging two 90 watt channels. That's why we all bridge our sub boxes.
Old Apr 2, 2008 | 06:24 PM
dB-SPL's Avatar
Hmm. Never did mention that I was a 'Know-it-all'. I simply stated facts about the amp that the OP is requesting the information about. Which I was pretty sure was the PDX-1.600 in which there are NO power gains from 'bridging' this amp.
Old Apr 2, 2008 | 11:22 PM
no one called you a "Know it all"... or wrong
Old Apr 2, 2008 | 11:23 PM
i must have missed that one, what prompted the sudden change?
Old Apr 2, 2008 | 11:32 PM
Bartak1's Avatar
Im not sure, I missed some of it myself.....I think it had something to do with gas prices
Old Apr 2, 2008 | 11:40 PM
Hey fellas, thanks for all the posts....kind of wish I had bought the 1X1000 rather than the 1X600 but the more I listen to it and tune it a bit, I am totally impressed with the sound. The PDX amps are SOOO much cleaner than my Punch Amps I had. No more AM radio noise, and it just sounds more clean and more punchy if that makes sense.
I am happy with the purchase, and I did spend a few hours dropping them down 2 more inches...that was fun.
My fosgate 6X8's door speakers sound pretty darn good for 3 ways.
I was only running 50 to them before now 100.
Old Apr 3, 2008 | 01:25 AM
Low_e_Red's Avatar
Uhh... ya... I think you are missing the point here. Because its supposed to be like that.... For example, bridge the rears for a sub and then run the fronts to spks...
P.S. 200W is more than 100W.
