Best spot to ground Amps mounted on back wall
Originally Posted by anaheim_drew
O.k I'm asking now
It's Craftsman Days at Sears and the meters are on sale,plus online discounts to club members
Any suggestions on models for a Craftsman and/or Fluke? I noticed online that Fluke has extended leads available
Extended leads are simple to make... Just grab some wire, a banana plug and whatever you want to use as a tip.
Originally Posted by Crewwzin
Find somewhere on the body close to the amps (within 3 ft), scrape the paint down to bare metal, and put a screw in it. If you dont wanna take the time to do it right, you might as well go ahead and half-*** it.
LOL I just thought many of you all have the best spot and save me the time and expense of buying 12 ft of 8 gage and a meter that I will use once
Originally Posted by shanecaseber
Cant someone just tell me where to ground my amps ?
Originally Posted by styxnpicks
I'm using gounding blocks that are screwed into the frame... had to drill and tap the frame. lol
if you don't have a multimeter I doubt your gonna have a tap set. gotta do it right tho
Ok Mr. Salty
LOL I just thought many of you all have the best spot and save me the time and expense of buying 12 ft of 8 gage and a meter that I will use onceI'm not trying to be an ***. My granddad taught me something long time ago that fits here..."Give a man a fish, and you feed him for a day, but teach a man to fish, and you feed him for a lifetime."
There isnt one "best spot". It all depends on where your amps are mounted, how much wire you have, and what kind of sheetmetal is nearby. I gave you the way to properly figure that out...its not my fault you dont want to do something for yourself.
How do I get the measurement of the resistance of the wire going to get the meter and some 8 awg I have a lot invested in this set up to cheap out for another 40 bucks. Thanks for the help ok
Originally Posted by Low_e_Red
Pretty much cant go wrong with ANY FLUKE! I use a Meterman...
You put one lead of the meter to one end of the wire, and the other lead to the other end. Make sure the meter is set on ohms. Follow the rest of the steps and you'll be good to go.
Got the DMM ,Well it looks like the "BEST SPOT" is right on the floor close to the amps after a lil sanding.
As for the good ground spot...
Let me see...
It's blurry, but look at the end of the wrench...
You can also break it loose with a four-way...
But.................................... do you see the small bolt next to it^? That's what I ended up using.
Tons more pictures in my sig btw...
