2-ch. amp behind HU?
Old Feb 11, 2008 | 09:15 PM
mcgjam's Avatar
Has anyone had success mounting a small 2-ch. amp behind their HU?
I'm looking at powering my 6.5 comps with a small amp. and the rear fill with the HU.
Thanks,
mcgjam
Old Feb 11, 2008 | 10:18 PM
Crewwzin's Avatar
Thanks,
mcgjam
Like, physically behind the head unit in the dash? I dont think there is a decent amp on the market that is that small.
Old Feb 11, 2008 | 10:30 PM
south_ms_sprcru's Avatar
yes it can be done, not so much directly behind the unit, but more like behind and below a bit, there are voids in the dash large enough to accomodate amps with conservative footprints. I had mounted my four channel inside my dash originally but once I added my sub amp I moved it to the back wall of the cab
Old Feb 12, 2008 | 05:48 AM
mcgjam's Avatar
Thanks for the info. I guess I'm looking for a location behind the dash. It doesn't have to be directly behind the HU. Also, any thoughts on what size amp could be squeezed back there?
Thanks again,
mcgjam
Old Feb 12, 2008 | 09:45 AM
the smallest most efficient amp possible, really depends on how much power you are trying to work with...also I wouldnt try and run it at anything lower than 4 ohms b/c of problems with the heat no dissappating properly inside the dash...i didnt have any issues running my four channel amp in there but it never was pushed hard enough to cause any problems
Old Feb 12, 2008 | 11:23 AM
GJ Screw's Avatar
Look at the Boston Acoustics GT series...Mounted a few of those in a 150 before...
Jon
Old Feb 12, 2008 | 11:32 AM
306stang's Avatar
don't see why it wouldn't work as long as the amp is small enough. give it a shot and make sure to follow up with some pics
Old Feb 12, 2008 | 12:13 PM
Sundevil2188's Avatar
Rockfords newer amps are pretty small and fairly decent, but you'd probablly end up paying for rockfords name in the end
Old Feb 12, 2008 | 12:28 PM
Devildog101's Avatar
Alpine PDX!!! As far as I know, they are all the same size, so you can either get a 2 channel or a 4 channel.
Devildog101
Old Feb 12, 2008 | 12:32 PM
GJ Screw's Avatar
Devildog101
Or Memphis.. same chasis as the pdx...
Jon
Old Feb 12, 2008 | 08:17 PM
Low_e_Red's Avatar
JL's new HD amplifiers. They are smaller than the PDX and available in 600/1 and 600/4
Old Feb 12, 2008 | 08:18 PM
Low_e_Red's Avatar
Jon
I highly doubt that. Memphis and Alpine are two separate entities. Like GM and Ford, they arent going to share parts.
Old Feb 12, 2008 | 10:16 PM
just*rollin's Avatar
i used to have an older mtx amp back there. the thing is just make sure that it is held down good and tight. so it won't rattle or anything like that.
Old Feb 12, 2008 | 10:25 PM
GJ Screw's Avatar
Yea.. Sorry, I have should of been more specific- the new memphis line is similar size as the pdx..not exact same size but really close.
the memphis 4ch is 10.51 x 1.91 x 8.66
the alpine is 10-1/8" x 7-9/16" x 2-7/16"
Jon
