JL Audio 250 Mono Amp Question
Originally Posted by jhogan20
On this amp I noticed there are 4 speaker wire locations.
++ on left and -- on right
I am connecting to a single 10" JL Stealth Box
Does it matter which + and - I use? Will on way bridge and one way not?
There is no such thing as bridging on a 1 channel.
thanks, so they just give you the option of powering 1 or 2 subs right? Either way you are sending the full amount of power? Sorry for all the questions, I'm learning as I go.
Looks to be a good setup,
Devildog101
Originally Posted by Devildog101
Yeah, they put two speaker outs on the mono amps so you could bridge 2 subs at the amp and not just on the subs. If that makes sense. Like Low_E said, for ease of wiring.
Devildog101
Devildog101
Bridge = Using the hot rails from multiple channels to increase power capacity.
Mono = 1 channel, does not have multiple hot rails, therefore can not be bridged
Parallel = Wiring common terminals together in order to lower resistance
Series = Wiring in a "daisy chain" one to the next to the next. + > - > + > -. This will increase resistance.
Originally Posted by Low_e_Red
parallel at the amps not bridge. That is different.
Later bro,
Devildog101
