Problem with amp not working?
Old Dec 27, 2007 | 02:10 PM
btag601's Avatar
I have a kenwood 350w KAC-6295. I just hooked it up to my factory head unit in my 2006 F150 xlt via a LOC, and it will not turn on. I have checked all of the power connections and the ground connections and they are all secure, i also checked the fuse in the amp and in the power cable and they are good. Any suggestions?
Old Dec 27, 2007 | 02:46 PM
Bartak1's Avatar
Is your turn on getting power for sure???
Old Dec 27, 2007 | 02:53 PM
btag601's Avatar
yes i have power because it turned on once before while i was hooking it up
Old Dec 27, 2007 | 03:56 PM
Bartak1's Avatar
That doesnt necessarily mean you have power now though
Wont turn on at ALL?? Or is a Protect light on or anything?
Old Dec 27, 2007 | 04:00 PM
TRITON_2002's Avatar
What are you using for the remote turnon power?
Old Dec 27, 2007 | 04:31 PM
Devildog101's Avatar
Lets just run through everything to be safe...
Where is your +12v source
Where is your ground hooked up
Where os your remote wire hooked to
Did you check both sets of fuses? (power wire and on the amp)
Like asked above, does the amp light up at all, go into protection or thermal?
Give us some input and we can rule out everything for you.
Devildog101
Old Dec 27, 2007 | 04:34 PM
btag601's Avatar
i FOR SURE have power running to the amp. 12v is to battery i checked and yes i have power all the way to the amp. Ground is to jack support onto chasis. remote turn on is through radio fuse in fuse box which also has power all the way to the amp. the little red light that is suppose to light up on the amp does not light up at all. i just replaced the fuses in the 12v power cable and the fuse in the amp
Old Dec 27, 2007 | 04:45 PM
Im assuming that if you have power all the way to the amp, that you have a DMM.
If so, test the fuses for continuity to rule them out.
Devildog101
Old Dec 28, 2007 | 03:06 AM
Low_e_Red's Avatar
Redo your ground. Ground to the main chassis not the jack or seatbelt bolts. Those are known to be intermittent grounds.
Old Dec 28, 2007 | 03:24 AM
DRJ's Avatar
DRJ
DMM time! only way to be sure is to test the leads on the amp
could also be a pinched remote turn on wire
Old Dec 28, 2007 | 09:38 AM
btag601's Avatar
i dont know what a DMM is?
I will redo the ground and see if that is it.. any suggestions on where to ground???
Old Dec 28, 2007 | 09:43 AM
Low-e-Red stated it above. A DMM is a digital multi meter. Is that what you used to confirm that you have power all the way to the amp?
Old Dec 28, 2007 | 10:00 AM
btag601's Avatar
yes i'm not sure exactly what its called but it looks like a screwdriver and one end you clip to the chasis and the other you touch to the wire and a light comes on
Old Dec 28, 2007 | 10:01 AM
Jditta's Avatar
Redo the ground, that is it I'm pretty sure. I had the same problem and have it wired just like you. I had the ground at the jack mount bolts, and the amp had power but wouldn't turn on just liek your situation.
Old Dec 28, 2007 | 10:17 AM
btag601's Avatar
where did you redo the ground?
