Amp wiring problem
Old Nov 19, 2007 | 07:14 PM
metallitera's Avatar
Question Amp wiring problem
Well I kind of went a little overboard with my wiring kit I think, it has 4ga. power & ground wire. I have an Alpine MRP-M650 and the connection lugs on the amp are too small for the 4ga. wire and I dont have, or cant find any connectors to fit the wire that will fit in the lugs. I used 8ga wire for the speaker from the amp and it fits fine in the lugs and I have some left over so I was thinking of making 2 pig tails to drop the size down, but I'm not sure of the best way to do it. I tried soldering(which i SUCK at) and I failed miserably.
Any other suggestions?
Red
Old Nov 19, 2007 | 07:26 PM
mSaLL150's Avatar
How do you suck at soldering? its so easy lol.
maybe you need an 8 gauge wiring kit. whats the power output on your amp? im thinking your going to need to fit that 4gauge wire somehow, someway.
Old Nov 19, 2007 | 07:34 PM
400w amp.
I got a kicker amp kit and it has terminals for the wire but they dont fit the amp lugs. I think I might MAKE them fit?
Old Nov 19, 2007 | 07:35 PM
edwards's Avatar
i know this probably isnt the answer your looking for but i would just go out and buy some 8 gauge wire.
Old Nov 19, 2007 | 07:37 PM
Bartak1's Avatar
Red
There are a couple things that I would try.
1. http://cgi.ebay.com/SOUND-QUEST-BY-S...QQcmdZViewItem
2. Shave the wire down if you can keep as many strands as possible, just enough to squeeze it in the terminal...
3. Stick a distro block in there and run a short length of 8 gauge from the dist block to the amp.
Old Nov 19, 2007 | 07:38 PM
Bartak1's Avatar
WTF, when I started to type my reply there wasnt a single one....now there are 3 before me
Old Nov 19, 2007 | 10:10 PM
Devildog101's Avatar
Either trim the wire strands down so it fits or you can buy a wire reducer. I know companies like stinger make them. They make a 4 awg to 8 awg reducer. You can also do like bartak1 said and just buy a distobution block that goes from 4 to 8 and a small piece of 8 awg and go from there. I would suggest the distro block.
Good luck, post pics,
Devildog101
Old Nov 22, 2007 | 03:54 AM
DRJ's Avatar
DRJ
LOL
