Need Some Help with amp installs and the back seat
Old Oct 20, 2007 | 11:28 PM
01rc51's Avatar
Hey guys, I just got a 05 Excab FX4, I mounted two JLs 300/4 and a 500/1 side by side on a 1/4 sheet of wood. And the seat back is a couple of inches away for latching does anyone have any ideas. I did a search and saw some S brackets someone had made. I just looking for any other ideas.
Old Oct 21, 2007 | 10:32 PM
kuruption's Avatar
I believe that was also done with the LMI seat lift installed which moves the seat forward about 2" as well as up.
Old Oct 21, 2007 | 11:51 PM
Low_e_Red's Avatar
Are you sure you are putting it on right? Cause mine fit no problems.
Old Oct 22, 2007 | 09:11 AM
01rc51's Avatar
LMI - not really needing to move the seat up for 200 bucks, and It goes on only one way i hope. I think I'm going to get some hose clamps and run them thought the back wall and to hook on to the seat and tighten them down. That's the best idea I can come up with.
Old Oct 22, 2007 | 01:25 PM
Devildog101's Avatar
Tell me if Im wrong guys... But dont you need to mount the amps "low" on the back wall if mounting behind the seat?
That may be the problem depending on how high or low on the back wall your amps are mounted.
Old Oct 22, 2007 | 05:10 PM
01rc51's Avatar
they are high I will move them down and see what happens, thanks
Old Oct 23, 2007 | 01:56 PM
Yeah, let us know. It seems to me from others installs that they need to be lower on the wall.
Im still trying to put both amps and a sub under the back seat because of this.
Good luck,
Devildog101
Old Oct 23, 2007 | 03:43 PM
01rc51's Avatar
going to work on it this afternoon will take some pics
Old Oct 23, 2007 | 05:03 PM
01rc51's Avatar
Sorry no pics battery was dead in the camera. It made some difference when I moved them lower but not much. I could not get the bottom to catch, going to try a thinner board. Did the hose clamp on the top for now, starting to rain again. I’ll work on it later. The 4runner and the jet ski are parked in the garage. Who would have thought that my corvette was easier to work on than this truck.
Old Oct 23, 2007 | 08:18 PM
How thick of a board did you use?
Old Oct 23, 2007 | 09:14 PM
01rc51's Avatar
I used 3/4 and I have some 1/2 and 1/4 I going to try. I'll let you know what happens.
Old Oct 24, 2007 | 10:16 AM
Cool, I hope it works.
Old Oct 25, 2007 | 12:32 AM
Low_e_Red's Avatar
1/4 May barely work.... Mine fit barely with nothing underneath. ( I know I know I shouldnt ground the amps chassis... Didnt have a choice at the time)
