Will this amp do?
Old Oct 15, 2007 | 04:49 PM
Unclebuck's Avatar
Will this amp do?
Subs(2) are Alpine 10" 50-300 watts rms (150 watts per voice coil),peak power 900 watts. (All greek to me) I plan on getting the Alpine amp, 600 watts rms x1 at 2 ohms, 400 watts rmsx1 at 4 ohms. Would this work? Thank you.
Old Oct 15, 2007 | 06:25 PM
GA FOO 88's Avatar
Get the dual 2 ohm VC's, on that alpine sub and youll be alrite.
Old Oct 16, 2007 | 08:22 AM
Unclebuck's Avatar
Thats what it has. So I'm gonna go ahead and do this. Thanks you.
Old Oct 16, 2007 | 01:34 PM
Devildog101's Avatar
Yep, it will work. Take some pics throughout your install...
Later,
Devildog101
Old Oct 16, 2007 | 04:02 PM
Unclebuck's Avatar
I certainly would, if I could do it myself. But I'm going to have to pay to have this done. You may as well ask me to fix the warp drive on the Enterprise as to do this. Wish I could cause I'm replacing head unit, four speakers, and adding subs/amp. Probably going to sting.
Old Oct 17, 2007 | 02:01 PM
There is enough "how to" threads on here to try some of the stuff yourself. You can at least install the headunit and front door speakers no prob, even for a noob. Trust me, try it out, you might save a buck or two in the process. If you run into any problems, just hit us up.
Later, and good luck,
Devildog101
Old Oct 17, 2007 | 02:10 PM
Unclebuck's Avatar
If I try it, I'm sure you'll be hearing from me! Thanks
Old Oct 18, 2007 | 01:10 AM
Low_e_Red's Avatar
Just let us know. Good luck
Old Oct 20, 2007 | 02:54 AM
DRJ's Avatar
DRJ
Rough estimate would be...$190 for install... <<stings
