how to bridge a amp properly
i have a 2 ch 1200 watt sony xplod amp, i was wondering how to bridge it, some people have both positive terminals hooked up, and others have a negative and positive hooked up, and others have the pos and neg hooked up and a wire connecting the other ops and neg terminals.
thanks
thanks
on most amps, if all 4 speaker terminals are right next to each other, its the furthest terminal to the left and the furthest one to the right that you want to use. One will be + and one will be -. look in your manual it should tell you. Also make sure to watch your impedances. Even if an Amp is capable at 1 or 2 ohms in regular channel form, they might only be 4 Ohm in bridged mode...
