Hi Input ???
Hi Input ???
Whats up F150? I'm hooking up my new amp. I have never used hi input. I have my radio out a bit so I can see the wires behind it. I'm trying to figure out which are the rear speaker wires so I can tap into them at the rear rocker panel by the back doors when you pull up the plastic floor piece. Also which one is the remote power antenna wire?
Radio 12v lt. green/purple + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/black or lt. green/yellow + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on dk. green/purple + radio harness
Notes: This is the subwoofer amplifier turn on lead. The subwoofer and amp are in the driver side rear corner of the cabin. The subwoofer speaker wires are brown/orange (+), and red/black (-) at the radio harness.
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Does that help you any?
Power Antenna N/A
I got tired last night and turned in after I ran the 4guage constant power. I guess I'll drill a spot in the floor pan to bring it in. I wanted to run it in one of those slits under the plastic molding where the factory wire bundle is but it's too big.
Originally Posted by Grant54
So for instance, RR orange with red stripe is negative???
