amp shuts off for no reason! HELP!
Old Apr 11, 2007 | 10:21 PM
05lifted50's Avatar
Question amp shuts off for no reason! HELP!
Ok, get this...I had a system in my truck and it worked fine never any problems. Recently, I removed the subs and amp and left all of the wiring ( power, remote, ground, rca's) built a custom fiberglass box got a kicker solobaric and new kicker amp and when I went to hook everything back up it worked fine for about 10 seconds then it shut off! Im talking perfect hard hitting bass and the nthe amp turns completely off . It doesnt go into protect, it just shuts off. I checked the rcas, and power and they were fine...the only thing I can think of is maybe a bad remote? The ground is also fine...so I got new remote wire and Im going to try that....does anyone know why this could be happening? Thanks guys!
Old Apr 12, 2007 | 09:26 PM
Bartak1's Avatar
Could be the remote wire. All your fuses are good?
Old Apr 12, 2007 | 10:51 PM
iceman6827's Avatar
the solobarics come in 2 and 4 ohm DVCs right? check your wiring you may be presenting too much load to the amp...if its a 2 ohm stable amp and the sub is wired for 4 ohms that could cause it to shut off
