Couple of simple questions
Old Apr 6, 2007 | 09:17 PM
martyapo's Avatar
I know you're not supposed to run RCA signal wires with power wire, but here's my question. Can you run speaker wires near power wires and can you run RCA's along speaker wires? Speaker wires are run off a 60w X 4c amp. I'll be running the 4 gauge power wire along the pax side floor plate and was wondering if I need a new route for the speaker wires on the pax side. RCA's are ran down driver side. Is it OK to run speaker wires along with RCA's?
Old Apr 7, 2007 | 01:44 PM
Bartak1's Avatar
Speaker wire along RCA's is fine.
Old Apr 7, 2007 | 06:31 PM
Impact9's Avatar
I've never had any problems running speaker wire next to power wire either. Long as you keep power and rca's apart you'll be fine.
Old Apr 7, 2007 | 07:25 PM
jmt0645's Avatar
^^exactly^^.but to further isolate my RCA's I ran them down the center *hump*
P.S: love the new truck Bartak
Old Apr 8, 2007 | 10:13 PM
Bartak1's Avatar
As what I plan to do with mine...just keeps them away from everything.
Old Apr 8, 2007 | 10:27 PM
jmt0645's Avatar
Yep
Old Apr 9, 2007 | 12:08 AM
6spdcoupe's Avatar
RCAs/Speaker leads and Power can all be run together - doesnt matter. Just alot of myths out there.
Although you can pick up EMI from your tranny tunnel if you have any ECUs near or around that area.
Old Apr 9, 2007 | 04:20 PM
jmt0645's Avatar
power does induce noise to the RCA's
no PCM or any wire in this area
Old Apr 9, 2007 | 07:06 PM
6spdcoupe's Avatar
Im hoping that your laughing is sarcasm, as power wire does Not induce noise into your RCAs. Not fiction - fact. Tried and proven numerous times over.
I dont own an F150, so Im unsure of what's there, hence the reason I said IF.
Old Apr 9, 2007 | 10:22 PM
jmt0645's Avatar
yeah, the first one was sarcasm, I like to aire on the side of caution anyway.
no harm done a
Old Apr 9, 2007 | 10:30 PM
Bartak1's Avatar
Good call, I never though of that.
I think (hope) our trucks are pretty bare around that area though, as JMT said.
Old Apr 9, 2007 | 10:38 PM
6spdcoupe's Avatar
no harm done a
Its all good. I still do it on most installs due to learning the 'old school way' back in the 80s.
Old Apr 11, 2007 | 07:15 AM
Impact9's Avatar
In the past I've had power induced problems. Course that was like 20 years ago so I pretty much stick with seperating wires when possible.
Old Apr 11, 2007 | 09:33 AM
martyapo's Avatar
I'd just like to thank everyone for their replies and support of the forum. You guys are great and I appreciate the advice and knowledge you share.
