Wire size recommendation
Old Apr 11, 2007 | 08:06 AM
martyapo's Avatar
I have 4 ga power wire ( Kicker amp wire ) running to an MTX 64w X 4 c amp and a Bazooka sub amp at @ 220w. Both amps accept 4 ga input but my distribution blocks are 4ga input with two 8 ga outputs. Will these amps still perfrom as well with 8 ga inputs (@ 8" long 8 ga ) as they would with 4 ga inputs? Also, should I individually ground each amp or send 8 ga from each to a distribution block and ground from the block with 4 ga?
Old Apr 11, 2007 | 08:57 AM
mtordie's Avatar
As long as your distrubition block is within a few feet of your amps, running 8 guage to your amps from a main 4 guage feed is fine. There is a mathmatical equation for it but you have very small amps that arent going to pull much current so it isnt worth researching.
Old Apr 11, 2007 | 09:24 AM
martyapo's Avatar
Thanks for the input. So it sounds like I'll be OK with 8 ga. Just wondering though, at what point (RMS watts) would it be neccessary to use 4 ga input to the amps? Also, does this apply to the ground as well?
Old Apr 11, 2007 | 12:55 PM
051fdrof's Avatar
8 AWG is good for about 50A (running the length of your truck) and 4 AWG about 100A.
50A = 350 watts RMS
100A = 700 watts RMS
Always ground your amps with the same gauge wire that's supplying the power, and ground as close to the amp as possible. Rinning 8 AWG grounds to a distro block and then grounding the distro block with 4 AWG is fine, but try to keep the total length under 3 feet.
Your main should be fused at around 70A, and each of the 8 AWG feeds should be fused at 40A.
