Amp location problem!
My '07 Supercrew is at the install shop right now getting a bunch of audio put in but the installer called and said they can only fit 1 amp behind the seat because of the motor for the rear slider, seatbelt pretensioers and several other things. He also said it won't fit under the driver or passenger seat because of the motor for the power seat. Where else can I put an amp in there that won't involve me having to move my jack? I've seen other people on hear install 2 amps behind the rear seat, so does that mean the '07 is different? Please offer any suggestions.
Assuming it is like my 05, I have 3 back there. But, I have two to the left of the seat belt bracket. One above the other. I had to cut some off the headrest post to get it to go flat. The two amps were too tall when stacked together. I put the other to the right of the bracket vertically. I had to rotate the black box that is on the side 90 degrees clockwise and put a new screw hole in. It can be done but, some mods may be necessary.
