Help with Amp setting
Old Jan 28, 2007 | 04:26 PM
chesster51's Avatar
I just installed a Rockford Fosgate punch 3002 (300 watt RMS) two channel amp to go with a set of Infinity Kappa 6 x 8 front door speakers. I'm using the factory head unit and no sub. I don't know much about audio and the amp has a switch with three settings, low pass, all pass or high pass. Also a wide range for crossover adjustment. With my setup, which is the best choice for the switch? Crossover?
Thanks for the help guys.
Old Jan 28, 2007 | 06:00 PM
6spdcoupe's Avatar
You want to put the amp on HP. From there you can put the variable setting to somewhere and around 80-100. If it sounds like they cant handle it (too much midbass) then just turn it a bit higher and take it from there. Trust your ears.
Old Jan 28, 2007 | 07:37 PM
chesster51's Avatar
Thanks for the help, just what I needed.
Old Jan 28, 2007 | 07:47 PM
6spdcoupe's Avatar
No a problem ! Let us know how it works out..
Old Jan 28, 2007 | 08:03 PM
chesster51's Avatar
One other question. Since I'm using the stock head unit, I also had to get a line converter to use with the amp. The converter has gain adjustment screws for both channels. Before install, I turned the gain on the converter all the way down because I thought it would be best to control it with the amp and not the converter. After the install I wasn't getting any sound until I turned up the gain on the converter. I guess I'm wondering how much the gain should be turned up on the converter to then adjust it on the amp.
Old Jan 28, 2007 | 08:08 PM
6spdcoupe's Avatar
I usually try to keep em somewhat low unless absolutely needed to go higher. Somewhere below half should be suitable.
