popping fuses???
popping fuses???
I'm popping 60 amp fuses on my 4 gauge power wire it's a brand new kit and made sure it is not grounding anywhere, it only does it when i'm jammin out loud. should I try like a 90 amp fuse or is there another issue? amp is 1300x1@2ohms.
any answers are helpful thanks
Originally Posted by Bartak1
Def. go with a bigger fuse...
90 might work..
What amp is it?
90 might work..
What amp is it?
i'm goin to put some diamond 10's in truck more leg room..
Originally Posted by somcoupe
infinity 1211a class D .. i dont have a cap yet, i just put it in my new car the lights dim big time tho so i will need one.
http://forum.realmofexcursion.com/sh...ad.php?t=17970
Originally Posted by Impact9
Don't get a cap they will do more harm that good.
I would try the bigger fuse. As for the dimming, you might think about running bigger power and ground wire and maybe doing the big 3 upgrade. I am running the amps in my sig with only a 60 amp fuse at the battery and have never blown a one. I have run in from over 2k watts to where it is now at around 1600. And I run only 4awg from the battery and 8 awg to each amp.
Whats wierd is when i had this amp in my f150 I had anonther 1200 watt for mids, pushing 2500 watts all together running the 4 awg and then the 2 8's like you are, and never blew one, The only difference I made is the amp is not bridged each sub is wired to a 2ohm load on seprate channels, I dont think that should be an issue should it?
I have was running 525 watts to my Chameleons and 900 to the subs for around 2k at full tilt and still no problems.
You are blowing fuses at the battery, correct?
yes blowing at the battery, asked a local shop hear and they said when it goes to seprate channels like i have it now it is dropping the load to 1 ohm I dont see how that possible but I just may wire them in series again if that is gonna fix it then I guess i'll do it.
Hold the phone. What type of subs do you have and what are the voice coils? The shop is either smokin something or might be correct. If you have dual 4 ohm voice coil subs, then they need an ohms lesson. However, if they are dual 2 ohm and wired in parallel, then this could be a problem.
LOL they must be smokin crack then, they are dual 4ohm L7 12's, I think I just may wire them in series anyhow. I figured they were prolly smokin somthin.
oh well i'll get a 1 ohm amp soon
