Powering the Germs?
Old Jan 19, 2007 | 10:32 PM
BigDave4's Avatar
Powering the Germs?
I am debating between two options for power to my new Germs.
Should I run my Bridged PG Tantrum 600.4 to them providing (according to the PG website) 300X2 or should I run my new US Amps MD22 to them, which would be 200X2. I am leaning toward the Tantrum bridged so that I can use the US Amps on my JL Sub.
Thoughts?
Old Jan 20, 2007 | 07:33 AM
dconder's Avatar
Thoughts?
You will not see a huge increase in level from 200 to 300 watts. Maybe 1.5 db but, that might be noticable. I think either amp will work well.
Old Jan 20, 2007 | 08:29 AM
BigDave4's Avatar
Agreed. I will likely go this route because the MD22 can push my sub well where the PG wouldn't do such a great job.
Old Jan 24, 2007 | 04:09 PM
6spdcoupe's Avatar
Use the PG and rather than bridging it, take advantage of the biamp capabilities.
Old Jan 24, 2007 | 04:12 PM
dconder's Avatar
So running each driver with 75 watts would be better than running 300 watts to the set? I have heard that bridging does reduce SQ some.
Old Jan 24, 2007 | 04:15 PM
6spdcoupe's Avatar
yessir. Then youll also have more independant control of the drivers. Often referred to as "the easy/cheap active setup".
