Best place to ground an amp for a 2000 Scab
I made a ground under the child seat restraint loop bolt with a big O-ring terminal. Also under the door floor panels are plenty of holes to run a ground right to the frame. Since your mounting under the seat just loosen up a seat bolt and slip a terminal between there. Rub the spot raw with sand paper first to assure a good ground.
