Where to run power wire
Hello!
In my '99' I ran my power wire through a little grommet in the floor. If you pop off the passengers side sill plate and look at the floor up around the kick panel area, you will see a grommet about the side of a half dollar.
Works nicely for me-You can run the power wire from the battery down ontop of inner fenderwell, then right back to the grommet. Mine is tied on to the frame some too. Comes in right under the sill plate where you can run it to the back sight unseen
Something to look at.
Originally Posted by fyerfytr
Do you guys typically put the power wires in a loom to keep from eventually shorting out?
thanks
thanks
YES! Its ALWAYS a good idea to have power wires covered. Most people end the loom once they get inside the cab, which is usually fine. Personally, I like to cover the wires all the way to the amp-you never know what could wear through an uncovered wire.
Extra protection is a good thing....hehe.
Cool Thanks much... Yeah I dont need a Truck fire of my own
Mark
Mark
My GMC caught fire from the fuel pump relay shorting out...made a mess of the engine bay..one of the reasons I traded it in on my F150
Originally Posted by Mobansheerider
Those suck
That sucks man.
I have a fear of my truck starting on fire... I would be mad...thats a lot of money down the drain
