Where to hook the ground wire in a 06 reg cab
Old Sep 30, 2006 | 09:18 AM
needz_a_f150's Avatar
were can i run the ground wire. everywere i try the screws are to big. im runing 8 gauge wire.
Old Sep 30, 2006 | 11:10 AM
nigdonht's Avatar
Where are your amps mounted?
Old Sep 30, 2006 | 09:24 PM
shtrdave's Avatar
Drill a hole.
Old Sep 30, 2006 | 11:50 PM
im going to try to mount it as close to the grounding point as possible. just dont know were that is.
Old Oct 1, 2006 | 12:25 AM
nigdonht's Avatar
try to keep your ground cable 16" or less
Old Oct 1, 2006 | 03:00 PM
Sluys's Avatar
Go to Radio Shack and get a ring terminal that fits the screw or bolt you want to use. Also, get some sandpaper to take the paint off your contact point to make sure you have a good connection.
Old Oct 1, 2006 | 08:38 PM
thanks for the info. i know how to ground and everything i was just wanting to know if anyone knows of a good spot so i don't have to drill. the ring terminal that came on the wire is small. i can drill the hole out a little bit but was trying to avoid that
