need amp
Old Jun 17, 2006 | 10:41 PM
dodge_slayer01's Avatar
need amp
i am buying two 10" L5 solar barics from a friend. he just got them and now he wants to sell them for 250 with the box. i need to know what amp is a good choice to push them. i am on kind of on a budget, so i need something around 250-300 dollars.
i am thinking of using this amp.
http://www.onlinecarstereo.com/CarAu...roductID=16343
here is the subs.
http://www.onlinecarstereo.com/CarAu...roductID=14811
Old Jun 18, 2006 | 01:13 AM
brypink2's Avatar
here is the subs.
According to those specs on the subs...they can handle 450 watts each. If you are getting 2 of them (2ohm DVC)...I would wire them to a 2ohm final impedance and get an amp that can handle about 1000-1200 watts @ 2ohms. I say this because I like a little bit of head room w/ my amps. If you set the amp properly you will have no problems.
I think Kicker has a 1200x1 amp...IIRC a KX or SX. Sorry, I'm not to familiar w/ Kicker. I'm not sure if you can get one for $250-$300, maybe used on Ebay...not sure. The Kicker KX and SX are decent amps from what I hear.
Old Jun 18, 2006 | 05:11 PM
would i be better with a 2 channel amp or a mono amp. i found two amps a best buy that are pretty nice.
2 channel
http://www.bestbuy.com/site/olspage....=1134701343037
mono
http://www.bestbuy.com/site/olspage....=1099388637322
Old Jun 20, 2006 | 09:07 PM
i am sorry i screwed up. the subs are dual 4 ohm.
so i am thinking of getting this amp http://www.bestbuy.com/site/olspage....=1099388637322 and wiring them like the second option http://www.the12volt.com/caraudio/wo...s.asp?Q=2&I=42.
tell me what yall think.
Old Jun 22, 2006 | 08:38 AM
Rider69's Avatar
You need something with more power than that Kenwood amp. It only puts out 500W RMS into 4 ohm.
Old Jun 22, 2006 | 09:54 AM
polo2005's Avatar
get a 2 channel amp like the audiobahn a8002v, it gives you 400w x 2@2ohms rms or 800w x1@ 4ohms. They cost anywhere from $120 to $170 on ebay and audiobahn makes some good audio equipment. go to this website and check out option # 1 and do it to both channelsn http://www.crutchfieldadvisor.com/le...pedance=DVC4x2
Old Jun 22, 2006 | 09:16 PM
why not? there would only be 250 going to each?
Old Jun 22, 2006 | 09:18 PM
i dont think that will work. i have 2 subs and both are dual vc at 4ohms.
