Is this the right size amp???
Old Apr 19, 2006 | 11:40 PM
BigCountry06's Avatar
OK, well im mounting 2 kicker comp 10's into a downfiring sub box for underneath my rear seat in my 06 f150 screw...while out doing some research, i spoke to a guy from circuit city, and he suggested the kicker kx700.5 amp........i dont have much experience in this field at all, so i have no clue what to look for...take into mind i will be adding the avic-z1 double din w/navy and dvd head unit, headrest dvd's, kicker 5x7-coaxials in the rear doors, and (?not sure about up front yet?) maybe some kicker 5.25's w/the tweaters to mount in the front door spots....was told i could fit the 5.25's and the tweater in the original speaker holes that are 5x7...does this amp sound like overkill or just right?....i listen to mostly country and rock, but i mainly want the setup so that the dvd's sound good, and so that when cruisin the beach it will turn some heads....is this a descent set-up? or am i all wrong with the kickers....??? i need help guys....thanks Clay
Old Apr 20, 2006 | 12:02 AM
dconder's Avatar
Not a thing wrong with that amp. Should work out just fine for you.
Old Apr 20, 2006 | 02:34 AM
IROC it's Avatar
I imagine that amp will shake some laffy taffy for real.
Sounds great.
Old Apr 21, 2006 | 07:05 AM
dang it....i was hoping you guys were going to say overkill....lol, that is a pretty expensive amp...lol thanks for the input though....
Old Apr 27, 2006 | 07:11 PM
Norm's Avatar
That is a great amp!
Old Apr 28, 2006 | 08:49 PM
Norm, i see you have the same amp....and i have read some of your posts, you seem to have a lot of knowledge in this area, so i have a few questions for ya.....which kicker door speakers would work best or something comparable....and with that amp how does it split up between the mids, highs, and subs?...and ill still be going with the 2-10" kicker comp 05c104's....ill be using the avic-z1 HU....any suggestions would help thanks....
