Opinions on this amp
Old Mar 27, 2006 | 12:38 AM
rustyzipper's Avatar
What would be the best application used, sub or speakers?
KEY FEATURES:
two-channel car amplifier
170 watts RMS x 2 at 4 ohms (250 watts x 2 at 2 ohms)
500 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
wired remote control for bass boost and low-pass filter
high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
bass boost (0-18 dB) variable from 40 to 100 Hz
Tri-way capable
MOSFET power supply
cooling fan
preamp- and speaker-level inputs
preamp outputs
requires 4-gauge power and ground leads
Cast Aluminum Heat Sink
Detachable Aluminum Dress Plate & Top Panel Control
Variable Bass Boost with Wired Remote
Built-in Variable Low-pass Filter
Built-in Variable High-pass Filter
Gold Plated RCA Inputs/Outputs
Speaker Level Input
Power MOSFET Switching Power Supply
Single-side Exposure of Terminals for Multi-Installation
Old Mar 27, 2006 | 01:21 AM
Lumadar's Avatar
paperweight? lol
Not a fan of kenwood amps, sorry..too harsh imo.
So if I had to choose, a single or maybe 2 low power consumption subs
Old Mar 27, 2006 | 08:05 AM
dconder's Avatar
150 x 2 to front components or 500 watts to a single 4 ohm sub. Should work nicely either way.
Old Mar 27, 2006 | 12:20 PM
I thought the amp was nice just in the fact it has a cooling fan.
I read so very many amp reviews where the reviewer almost always will complain about his/her amp running to hot.
I thought the amps remote was also a nice feature, being I wanted to keep the factory single CD head unit.
