Whats the best place for the amp?
Old Oct 24, 2005 | 02:27 PM
05blkFx4's Avatar
I was wondering where would be the best spot to put an amp in my 05 crew cab. I thought about behind the back seat or under the front passanger seat. I also am going to run a capicitor and would like to keep the amp and cap together. Would there be enough room to keep them together under the passanger seat? Thanks
Old Oct 24, 2005 | 10:19 PM
golferdude1971's Avatar
Im having my install done on friday, and they will be installing my two amps behind the rear seat.
Old Oct 25, 2005 | 01:00 AM
05blkFx4's Avatar
Yeah thats what I im going to go with. Let us know how it goes and some pics would be nice to get an idea. Thanks
Old Oct 26, 2005 | 03:26 AM
brypink2's Avatar
I'm putting 2 maybe 3 amps (depending on what I decide on) behind my rear seat. A Viper d2500.1 and 1 or 2 McIntoshs. I will run them initially with normal ventilation. If they run too hot, then I will install some fans. The McIntoshs have built in fans, though.
Also, not sure what you will be running, but the cap is a waste of money IMO. It might give the added power when needed, but it still draws from the battery which is the reason you are buying the cap to not do in the first place. At the minimum, do a Big 3 upgrade and look into buying a better battery and maybe an HO alternator if you experience any dimming.
