How To Fold Down Rear Seat Question
Old Jun 9, 2005 | 05:11 AM
Josiah's Avatar
Reference
In the above referenced post, it shows only the 04/5' rear seats, and even then it's barely understandable. Is there a way to fold down the rear seats on namely the 02' f-150 supercab?
Appreciate the response(s) to come.
Old Jun 9, 2005 | 10:32 AM
rockafella's Avatar
If you have the owners manual (in your glove box) it will show pics of how to do it. Either the whole thing folds via a lever on either side at the base or you have to pull the bottom cusion up from the back and roll it forward, then the back part should fold down onto the floor. But the best way is to check the owners manual.
Old Jun 9, 2005 | 02:35 PM
Josiah's Avatar
will try this out and post my results, thanks.
Old Jun 9, 2005 | 04:11 PM
Bartak1's Avatar
On my 99 there is a strap where the seat belt latches are and you pull on that, then the seat rolls foreward like rockafella said. But in the supercabs the back rest doesntfold down, not on mine anyway. There is a pan under the rear seat and when its folded forward the whole thing just makes a nice flat spot.
Old Jun 9, 2005 | 07:15 PM
RockyJSquirrel's Avatar
On the '02 SuperCAB, the rear seatback does not fold down. It is attached to the rear wall of the cab. There's a couple tricky little clips you need to release in order to slide the seatback up and remove it.
Old Jun 9, 2005 | 09:31 PM
Durew's Avatar
What about a '98 Supercab? The rear seats fold down but I dont know if the back does.. cant find it if it does
