Blaupunkt Amp Question
It's been a long time (20 years) since I worked with upgrading car stereos. That has changed, since I was just given a new Blaupunkt PCA450 amp and need to know if I should use it in my truck, and if so, the best way to utilize it.
I have an '01 SCrew, with the factory 6 disc changer and HU, and have recently replaced the 4 stock speakers with Blaupunkt PCX573 (also free, so whether good or bad I still thought they'd be better than stock).
If I use the amp, what should I be powering?
I would rather run the stock locations and not add a sub, but if adding the amp to the mix is going to be less amps than the factory HU, then I may use the amp to power a sub at a later date.
Thanks in advance
KingRanch1
Thanks in advance
KingRanch1
Well, if your speakers can take 50 watts rms, Id just put the amp on the speakers.
Blaupunkt is ok-I wouldnt buy one, but if you got one free, meight as well.
If you stay with the stock HU dont forget a LOC converter.
Or you could put 2 channels on the front speakers and bridge the last 2 for a sub. Just another idea
Good luck with wahtever you do
