Auto on lead???
Old Jan 4, 2004 | 07:33 PM
Dupuis's Avatar
Auto on lead???
Can anyone tell me what I can hook the auto on lead to. I have easy access to my fuse box, but every thing in there stays hot. I added an amp using my stock radio and I am trying not to have to take the radio out. Even if I did, I would not know which wire to hook it up to. Any suggestions???
04 F-150
Old Jan 4, 2004 | 09:55 PM
Deus's Avatar
Hook it up to the accessory or line behind the deck...[ghetto]or use a switch.[/ghetto]
Old Jan 5, 2004 | 12:58 AM
Invalid_access's Avatar
If you really wanna ghetto rig it. Just hook a jumper wire to the remote from the 12 volt wire coming off your battery with a in the middle of the jumper wire. That way you can cut it on and off. I'd imagine this method would get old after a while. Switching amp on and off everytime you wanna hear it.
Old Jan 5, 2004 | 10:50 AM
bwhitt's Avatar
i believe the cigarette lighter is switched. the amp turn-on lead doesn't draw much power, so you could probably tap the hot lead without a problem. of course, the amp would be on whenever the truck is on regardless of the state of the radio. i don't know if any speaker-level to rca converters have this feature, but it would be nice.
Old Jan 5, 2004 | 11:27 AM
Dupuis's Avatar
I checked, the cigarette lighter is not switched, it works with no keys in truck. I don't like the switch thing, it would get old fast and I know I would forget to trun it off. I guest I will have to remove the radio and stab wires until I find the switched one for the radio. Sure is a lot of work for one little wire. Thanks for the suggestions.
Old Jan 5, 2004 | 08:49 PM
Bartak1's Avatar
If you pull out the radio the switched wire is the black one with the red stripe(in the drivers side harness) I spliced into this, also put a switch on it.
If you dotn have the tool to get your radio out, this is what i did. Pop off the panel around the radio/heat/ac controls etc, then stick a peice of flat metal about 3 high and however long(so you can hold it) and shove it in each side. This pops the clips and gets it out.
Old Jan 6, 2004 | 11:07 AM
Dupuis's Avatar
Thanks Bartak1, but why did you put a switch on a switched line? I see you have an 99, I wonder if the 04 switched wire is a differant color.
Old Jan 6, 2004 | 06:52 PM
Bartak1's Avatar
I put a switch on it so my amp isnt on if I tunm off the radio with the switch, and sometimes when someone is tolking on the radio the voice is to bassy and hard to understand so I can shut it off.
Im not sure if the wires are different colors or not, I jsut tool my turn on lead wire and stuck it in each little hole till my amp turned on.
