where should i run the battery wire?
Old Aug 22, 2003 | 08:57 AM
juztyn's Avatar
I'm trying to install a system for a friend, he has a 00' F150 Sport Reg Cab, I'm a chevy person myself (no flames please ) and I dont really know where to drill for the battery wire (4 gauge) - or is there a place i can run it through? i wanted to make sure i didnt drill through any lines or anything. its on the passenger side. also do the side panels just pop off so I can pull the carpeting up or what? thanks.
Old Aug 22, 2003 | 10:50 AM
neck4752's Avatar
Not sure about the 00'
I have an 03' and there is a hole in the firewall, its on the driver side, you just have to run the power wire over or behind the throttle body cover. The hole is up above the pedals, covered with a rubber thing. I ran 4ga. wire also. And on my truck yes the plastic siding did just pop off, and you can get under the carpet. Good luck.
oh yea and ford rules man! you should look into one.
Old Aug 22, 2003 | 02:35 PM
Deus's Avatar
There is also a hole on the passenger side under the plastic door sill.
Old Aug 23, 2003 | 05:34 PM
juztyn's Avatar
bahh you'll never convert me... i raced my 1500 v6 vs a f150 v6 and blew him away. CHEVY FOREVER!!!! (uh-oh here come the flames)
Old Aug 23, 2003 | 05:52 PM
Invalid_access's Avatar
Door sill is where I bought mine into the cab. You can ground off the bolts of that plastic thing that comes in the truck. That is what i did and I didn't even have to remove any paint.
