Got a new amp
Old Jun 26, 2003 | 09:59 PM
xbwfo's Avatar
Got a new amp
Can someone tell me if I can bridge a MTX Thunder 152 amp to a 2 ohm load?
Its a 2 channel amp, MTX says it will work bridged to a 4 ohm load.
Will it blow if I hook it to a 2 ohm load?
Old Jun 26, 2003 | 10:21 PM
TEK2000's Avatar
If MTX says its stable to a minimum bridged load of 4 ohms.. DO NOT go below that. It MAY not initially damage your amp.. but it is not designed to operate at 4 ohms minimum bridged and will cause nothing but problems and seriously shorten the life of the amp.
If you drop it to 2 ohms bridged.. you're forcing an increase in the current output of the amp and the internal components are not rated to handle the increased current draw.
Old Jun 26, 2003 | 11:11 PM
2Trucks1Wife's Avatar
What he said ^^^ don't do it unless you want to buy another amp in the near future.
Old Jun 27, 2003 | 12:06 AM
xbwfo's Avatar
Thanks guys, NO GO it is
I'll use it for my tweets........Just got an Eclipse 8443 and I plan to do a tri-amp setup.
