briding my amp
Old Mar 26, 2003 | 11:00 PM
WHITE4.2F150's Avatar
briding my amp
ok..i have a RF punch 250...and i have (2) 10" kicker impulses....i was wondering if i can bridge the two speakers....two negatives in left channel...and 2 positives in right channel...b/c i want my system a lil louder...or do i have to keep them in parallel??..anyone who knows...tell me b/c im in dire need of any info
Old Mar 26, 2003 | 11:03 PM
i found this in case anyone ever needs it..
http://www.rockfordfosgate.com/rftech/wiringwizard/
Old Mar 27, 2003 | 09:04 PM
Invalid_access's Avatar
My brother has my bridged punch 360 a2. You take the positive on one post and and negative off the other channel and that makes a bridge. It sounds better bridged if you ask me.
Old Apr 13, 2003 | 12:16 AM
83_F-150_302's Avatar
First you must know what ohm your amp is stable at. If you bridge a 4ohm stable amp bridged to two 4 ohm subs in parallel you will create a 2 ohm load and your amp won't be able to handle that and can overheat and fry. You also need to know that most 2 channel older aged amps were only made stable in stereo mode. That means each channel would be stable at 2 ohms but of you bridge it you'll only be stable at 4 ohms. Newer 2 channel amps are mono mode stable at atleats 2 ohms. So you can bridge the amp mono with 2 4 ohm subs in parallel and be good.
