Amp Wiring
Amp Wiring
Hi everyone, a friend of mine is putting subs in his 01 SuperCrew with the stock stereo. I will be helping him install it and we need to know how to get the signal to the amp. I just put some subs in my Maxima and I tapped the rear speakers with an adapter. Is there something we need to do similiar to this for his truck? Thanks!
Thanks for the info. I used the PAC SNI35 adapter in my car. Here is a description of it:
"The model SNI-35 is used to add an amplifier to a stereo which has speaker level outputs (typical factory or aftermarket stereo and two or four speaker system). Adjusts each channel separately to convert 2 to 30 watts of stereo power per channel to the precise level of pre-amp RCA output level required for the amplifier that is added."
Will this work on his truck? Also, where should we wire the turn on wire for the amp? Thanks!
