INPUT question
INPUT question
here is the quesstion........i put both inputs into the amp. sounds good. if i take one of the 2 inputs out (doesnt matter which one) the subs still work.....but are MUCH louder....almost like they're overdriving or something. they are mtx 8000's ...2 10's so , this being my first set of subs.....i do not know if it wired wrong.....or if the subs are just overdrived when one input is pulled out. is it safe to run it with jsut one input???
MTX 8000 4 ohm . not sure SVC or DVC.......i am pretty srue the (+) and (-) are right. If you pull one input out on yours if you have somethign similar ......does it get louder? the speakers are wired in "parallel"
I don't see how it is louder with one input...maybe you should have a local shop check it out.
yep i had a shop check it out yesterday. It was out of phase, meaning i had 1 set of wires which had the (+) and (-) mixed up, in this case it was behind the dash. The reason it was louder was because the 2 signals were essentially cancelling eachother out. The bass is nearly twice as loud now and very clear and crisp!
