Deciphering rear housing codes.
Old Jun 13, 2021 | 01:23 PM
Daleford's Avatar
I understand there is a code in the door jamb decal that describes the rear housing in an F-150. My problem is I have 2 rear housing assemblies here from salvaged trucks and the trucks are gone. One was a '16 and the other an '18. I find a code on tape wrapped around the rear tube of each housing. What do those codes tell me?
I have S808A and SB78A.
Old Jun 13, 2021 | 02:13 PM
Roadie's Avatar
Are there any tags on the diff rear cover bolts? That is where the info is supposed to be.
Old Jun 13, 2021 | 02:17 PM
Daleford's Avatar
Not that I know a lot about this but I haven't noticed that metal tag for a few years now. I thought they went to the tape around the tube?
Old Jun 13, 2021 | 02:53 PM
https://www.unitedtruckdism.com/used...MBLY_RR/45655/
Looks like S808A is a 3.55 open 8.8 out of a 3.3 liter with electric e-brake. No info on the SB78A, look at it again.
Old Jun 13, 2021 | 08:47 PM
Daleford's Avatar
Originally Posted by glc
https://www.unitedtruckdism.com/used...mbly_rr/45655/
looks like s808a is a 3.55 open 8.8 out of a 3.3 liter with electric e-brake. No info on the sb78a, look at it again.
thanks
Old Jun 13, 2021 | 08:57 PM
Daleford's Avatar
Originally Posted by Daleford
thanks
Not close enough to recheck that latter code but I'm guessing it should read S878A.
Old Jun 13, 2021 | 09:54 PM
Looks like you also had this issue 3 years ago -
https://www.f150online.com/forums/20...axle-code.html
Looks like the S878A is a 3.73 open 8.8 out of a 3.5 NA.
https://subwaytruckparts.com/cars/us...50-xl-3-5l-4x2
The S808A is probably out of the 2018, the S878A is out of the 2016.
Old Jun 13, 2021 | 10:04 PM
Daleford's Avatar
You are correct and you have a better memory than I do! THANKS
So neither of these rears have a metal tag attached. Did Ford quit using the metal tag and go to the tape in recent years?
Old Jun 13, 2021 | 11:47 PM
I believe so. Now - I don't know if they are standard 8.8 or Super 8.8. Standard has 10 bolt cover, Super is 12 bolt.
Old Aug 24, 2021 | 01:23 PM
Boostedx2's Avatar
Thanks!
