Courtesy wipe issues
We see it a bunch. More than likely it is a problem with the turn signal switch sometimes the steering column control module that comes with the switch as well. The steering column control module has to be flashed and the turn signal switch does not. Usually the switch is pretty cheap and not to bad to change. Check out pricing on here. https://www.bigdealford.com/
