2015 F150 electrical system seems haunted
Old 06-14-2018, 09:09 AM
Stewtex's Avatar
Pushed the brake and start button. Heard a pop and lost all electricity. Cleaned terminals and tightened securely. Continuity tester indicates power to the poser distribution box. The passenger compartment fuse panel is showing continuity at the 30A circuit breaker only. All other lower amp fuses beneath the breaker show no continuity. Pulled three random fuses and none were blown. While standing in the drivers door, I hit the horn, for no particular reason, and got a weak honk. As I walked back to the hood, the horn honked fully, as if I had locked it. Tried it again with same result. There was about 5 seconds between the honks. Any ideas or should I call a priest?
Quick Reply: 2015 F150 electrical system seems haunted
