Should I wait for the Diesel?
Question..
Current F1 KR has 160k on it so it's time for a new truck. I'd really like to get the exact truck I have now but with a different engine. I've been leaning heavily towards the larger EB but with the new diesel coming out in spring I'm considering waiting.
In your opinion would the new PowerStroke be a better fit for an F150 lifted with larger tires or just stick with the large EB? Given the gas mileage estimate for the diesel, savings on a fuel would eventually offset the additional engine cost especially with a lift and large tires
Lift is probably in the range of 4-6" and tire size probably looking at 35's or larger
If you are referring to the High-Output 3.5L EB as the large ED you won't be able to get it in a King Ranch. The High-Output EB is only available in the Raptor. The regular EB is a good motor with plenty of power and low end torque to turn oversized tires or pull trailers. I would think the diesel is going to have plenty of low end torque as well.
Unless you plan on towing something really heavy often, diesel isn't worth the hefty extra price tag IMO. Diesels are a bunch more $ to maintain as well.
3.5 EB has plenty of power for bigger tires or even if you tow something heavy occasionally.
I've driven both diesel and gas trucks for years. I don't know if I'd see much purpose buying a F150 diesel, when the ecoboost will likely outperform it with cheaper maintenance.
On the other hand, a F-Superduty... then no doubt diesel.
Yes, the 6.2 is fine. However, if you plan on just using the truck as a tow rig, then a diesel is worth considering.
I highly doubt the diesel in the F150 will tow as well or drive anywhere close to as well as the 3.5EB. It's down a lot of horsepower and a good bit of torque, something like 100 hp and 50ft-lb at similar engine speeds. It will get better gas mileage but it's not worth it. The ROI will be nearly 200,000 by the time you add in the extra maintenance on a diesel. Nope, if I'm getting an oil burner it will say Super Duty on it.
Thx for the feedback guys I really appreciate it. The 3.5 EB is what I'll go with. Once Truck Month gets here I'll pull the trigger. I've heard from several people like most of you mentioned the additional maintenance cost for the diesels and all of your feedback just affirms it. I don't tow often but when I do it's either my boat or UTV on a trailer. Doesn't sound like it's worth the additional cost / headaches that come with diesels.
With larger tires and lift I just wanted that extra bit of fuel mileage. Given your feedback I'll just stick to the EB. Thank you again!
