Grinding front end when cold 2016 F-150 3.5 EB
Old Feb 2, 2018 | 12:47 AM
Utemagna's Avatar
When the weather is below 30 degrees my truck will intermittently grind from the front end. I’m on my second Integrated wheel ends, but that hasn’t fixed the issue. This started happening during the first winter I owned the truck, so less than 8,000 miles and it happens fairly regularly.
Old Feb 2, 2018 | 09:06 PM
mycrazykidz's Avatar
I have the same problem with my 13 f150 if I figure it out I will let you know
Old Feb 6, 2018 | 03:17 PM
tcp2's Avatar
Replace the check valve in the line right by the vacuum tank. Driver's side right up by the firewall.
IWE checkvalve
Checkvalve Checkvalve
