door lock honk
Why? I press mine just once to lock all doors and only press it twice to confirm (by hearing the horn) that it HAS locked.
But, if there's a way to disable it, you can probably find it in the owner's manual.
If you have the key pad on the door, hold down the 7/8 and 9/0 buttons at the same time and you can lock the truck with it running, or with it not running and the keys in the ignition.
Edit: I just looked at the section on Locking and Unlocking in the 4th printing of your Owners Manual (downloaded here: https://owner.ford.com/tools/account...h-results.html), and sadly, I don't see a way to disable the honk. Could you change the activation of the remote start to the "Unlock Button" instead of the "Lock Button"? Since you're going to drive the truck after starting it, it would seem logical to unlock it. Perhaps, if you were not going to be in the truck immediately, you could then hit "Lock" again once after starting it.
- Jack
