Looks good...do you have a side view thats not taken from an angle(sorry im being demanding!)? Hows the 1.5" level, any rake towards the front?
I have a slight rake which is what I prefer. To the center of the fender well from the ground the front is measuring 39 inches and the rear is 40 inches (that is with about 200 lbs, my stock tires, in the bed). It might raise up a bit when completely empty but I doubt much.
Did it give you a true 1.5 inches of lift? Heck I might just do 1 inch.
I put 60's on and still stock. Need to get something done in the couple months so it doesnt look as stuffed.
I would say yes but I have been kicking myself because I forgot to measure it before I did the install.
To the best of my memory the front was around 37 inches stock. I did measure a few weeks back when I ordered the spacer. I am at 39 now with the level plus the size larger tires.
This is the toyos in a 60 stock susp. for reference. Dont know how they actually size up against each other. Now I have some thinking to do about what I want. Never tried a spacer kit before only bilsteins 5100s or actual lifts.
Btw your truck looks nice. If my tundra wasnt a similar color I would have ended up with that color.
I had a 2.5 spacer on my 2005 and ended up with front end issues after about 30000 miles. I replaced them with Rancho quick lifts and never had another issue.
That is one reason I only went with a 1.5 spacer. The only lift shocks that I could find for the 2015 ore the Fox and they are over $700 for the set. I hear that Rancho is supposed to be out with some quick lifts (around $360) for the 2015 at the first of the year so I probably will switch to those when they become available.
I really like your white truck. I almost went with white but when I saw a ruby red in the sunshine I knew that was the color!
