What Happened???
The 2015 F150 is not the first vehicle built with an aluminum body.
http://www.paintgages.com/List-of-Ca...anels-s/51.htm
With steel/aluminum interfaces or any dissimilar metal interface, galvanic corrosion occurs in the presence of an electrolyte (salt water). Another issue to think about. That is why saltwater outboard motors have zinc sacrificial anodes in their cooling systems and on the outside. The zinc has the highest electropotential and the corrosion eats up the zinc first saving the other metals.
The new Ford truck owners in the rust belt will be the first to find out if Ford protected the 2015 trucks effectively from this issue.
I think you're going to find a lot more aluminum in truck (and car) bodies in the very near future due to CAFE regulations. Lighter weight - with similar or greater strength - equals better mileage. GM and Ram (Dodge) are taking shots at Ford for going to aluminum, but they're also both working very hard on their own aluminum trucks.
Sure, there will be issues with the new F-150 just as there are in any new vehicle. Knowing how much of Ford's financial future rides on the F-150 though, I think we can be pretty sure they've done their homework on this one.
It wasn't the lack of sleeves that did it in, it was the iron head on the aluminum block. Aluminum heads on iron blocks are a lot more stable.
Yeah it was. Every vega I ever heard of and I also owned one of those pos's burned oil like crazy. If you ever saw the head of one you would see that the head was very tall to provide rigidity.
Its a well know n common issue, between the factory grill and hood. Not a dealer installed option
I owned one of those POS too. The reason it burned oil is the head gaskets leaked (dissimilar metal expansion/contraction), coolant would get into the cylinders and eat the bore coating.
Kinda curious to see how all of this play's out...
Not just corrosion, but repairability...
I left the autobody trade in 98...at that time most shops were not equipped to handle more than cosmetic repairs on aluminum...and plastic for that matter...If you use the proper primers, then getting stuff to stick shouldn't be a problem...but welding...that is a different story...
I also wonder how high the insurance premiums are going to be since it will probably take years for the chinese to produce aluminum aftermarket sheet metal...I believe that almost every Insurance carrier has an aftermarket parts clause in their policies...
Regards!
Regards!
My wife is one of the lead metallurgical engineers for a supplier that supplies most of the aluminum body, I can assure you there is an enormous amount of effort going into this truck to make sure there are no corrosion issues. I was confident enough to buy one knowing that.
