Cold causes P0304 misfire on Cylinder 4?
Old Nov 11, 2025 | 12:18 PM
dburgjohn2's Avatar
5 Year Member
My truck has started setting the P0304 code when the temperature drops, usually first thing in the morning. After engine and air temp warm up, no problems. I replaced the coil, what else could it be?
Old Nov 11, 2025 | 02:45 PM
Truck details, please? Year, engine? Miles on it? Miles on the spark plugs and the rest of the coils? What brand coil did you use?
Old Nov 11, 2025 | 03:55 PM
dburgjohn2's Avatar
5 Year Member
Sorry, 2012, 5.0 V8, 230,000, about 70k on plugs, coils are original, replacement was Motorcraft
Old Nov 11, 2025 | 06:34 PM
It's about time for new plugs, and maybe more coils. Are you sure you replaced #4 coil? That's back cylinder passenger side.
Other possibilities are injector or compression (valves).
Old Nov 18, 2025 | 11:58 PM
tbaz's Avatar
I’m just got my truck back from exact same issue .
140km on new warranty engine due to same issue but cylinder 8 .
so same issue , turns out exhaust valves burned , rings worn and cylinder head was glossed up . Long story short on my 2012 5.0 , needs a lot of labour and parts if I want to attempt to fix . IMO common problem with these engines , not worth the 5-6 thousand fix .
