First Truck, should I buy this 2010 F150 Lariat with 176k miles?
Old Apr 12, 2023 | 09:26 PM
Mekaiyo's Avatar
Hello Everyone,
I just bought my first house and I am wanting to buy my first truck. All throughout my life, I have driven Japanese cars that easily topped 200k miles with no major issues at all.
I want to buy this 2010 F150 Lariat with 176K miles for 15.4K. Does this truck have a higher longevity than what most people are saying? I have been hearing mixed things about the 3V 5.4L motor. The truck does not have any rust at all as it has been in the south all of its life.
Old Apr 12, 2023 | 10:35 PM
If the engine is quiet it should be okay. No spark plug issues in the 2010, it has the updated heads. However, there is the VCT/cam phaser system you have to be aware of, when it starts making noise you are looking at a $2000 repair for a full timing job. I would personally look for a 2011 or newer with a 5.0.
Old Apr 12, 2023 | 10:38 PM
Mekaiyo's Avatar
I will be test driving the truck Saturday and will be paying close attention for engine noise such as cam phaser tick. 2k doesn’t sound too bad, if I were to get this truck I would save money as an emergency.
Old Apr 12, 2023 | 11:54 PM
Other than the cams and timing system, the 5.4 3v is a solid engine. Ticks could also be cam followers (lifters), cylinder #3 is weak, Cam bearings are integral with the heads and caps (direct contact) but they can be machined for bearings. I've heard of them going 400k, but also heard of them going out before 100k. Engine is sensitive to keeping the oil clean, correct grade, and proper oil filter. Can't go wrong with Motorcraft 5w20 synthetic blend and Motorcraft filter, change every 3 to 5k.
Old Apr 12, 2023 | 11:57 PM
Mekaiyo's Avatar
Thoughts on using 5W30? Also if I don’t drive much which interval should come first to be safe , time or miles?
Old Apr 13, 2023 | 09:17 AM
serotta's Avatar
My Brother has a 2010 Lariat 4x4 5.4 with around 285K on the clock. He did have a catastrophic engine failure beginning in the #3 cylinder at 210K. He bought a reman motor for 5000K installed. It's been running like new since the new motor install. Everything else about the truck is still functioning as new.
Old Apr 13, 2023 | 09:33 AM
Roadie's Avatar
If it were mine, I'd probably run 5W30.
Old Apr 13, 2023 | 10:18 AM
I bet that was the follower.
Old Apr 13, 2023 | 10:34 AM
Mekaiyo's Avatar
How much was the reman motor and labor? Where did he purchase it as well? @serotta
Old Apr 13, 2023 | 10:35 AM
Mekaiyo's Avatar
Would there be any signs of the follower going out?
​​​​​​​https://www.youtube.com/watch?v=ChUcIwikVhU
Old Apr 13, 2023 | 11:01 AM
Mekaiyo's Avatar
Do ya'll also recommend full syn or syn blend for the oil?
Old Apr 13, 2023 | 12:09 PM
serotta's Avatar
He paid $5000.00 for the reman motor and the complete install through a neighborhood garage that he trusts. The guy did the initial teardown for discovery and recommended the reman dealer. Place called PowerSource for the engine, 3000 dollars and change, the rest to the garage for teardown on old and install on new.
Website:
https://www.bestrebuiltengines.com
Old Apr 13, 2023 | 12:30 PM
Yes, ticking. Watch the video.
Motorcraft blend and Motorcraft filter.
Old Apr 13, 2023 | 02:17 PM
Mekaiyo's Avatar
Would it be a safer route to get a F150 from 2011-2014 with the 5.0?
Old Apr 13, 2023 | 03:31 PM
In my opinion, yes.
