Ignition or starter
Old Oct 3, 2022 | 09:43 PM
Gwr1's Avatar
Ignition or starter
Yesterday I went to start my 2010 f150. Turned the key starter engaged key back to run but starter was still engaged had to turn key off to stop starter. Key switch was a little rough so I changed it also ignition switch no help
Old Oct 3, 2022 | 11:11 PM
Normal behavior. I think it will stop cranking after 10 seconds if it doesn't start.
Old Oct 4, 2022 | 09:51 AM
projectSHO89's Avatar
Yes, that is the normal behavior of the OTIS feature. All you have to do is momentarily turn the ignition switch to START and release it and the computer takes over the starting attempt.
Old Oct 4, 2022 | 11:08 AM
Gwr1's Avatar
Starter
When I release the key it goes back to the run position but the starter is still engaged have to turn key to the off position to stop it. I changed the key switch yesterday it works good also the ignition switch.
Old Oct 4, 2022 | 11:47 AM
Do I have to repeat myself?
Old Oct 4, 2022 | 11:49 AM
Gwr1's Avatar
No you don't
Old Oct 4, 2022 | 01:16 PM
Gwr1's Avatar
Fuse #27
Thank y'all for your help. It was fuse #27 that was bad.
Old Oct 4, 2022 | 01:45 PM
F27 would only affect the fuel pump You didn't say anything about the engine not starting.
Old Oct 4, 2022 | 02:15 PM
Gwr1's Avatar
Starter
Didn't know that the starter would stay engaged if the motor started.
Old Oct 4, 2022 | 05:22 PM
It won't stay engaged if it starts. If it doesn't start it will stay engaged for about 10 seconds.
