Gas Door Not Closing
Old May 8, 2022 | 08:57 AM
Du4's Avatar
Du4
I have a 2013 Ford F150 XLT 5.0 Supercrew. I noticed that the door for the gas tank inlet does not close flush with the body. Is there some type of adjustment, spring or other device that controls the door?
Old May 8, 2022 | 10:38 AM
gDMJoe's Avatar
Lightbulb
» 09-13 fuel door cover spring repair ««« -click-
*Result from Google [ site:f150online.com fuel door ]
Old May 8, 2022 | 05:03 PM
Du4's Avatar
Du4
Thanks.
Old May 16, 2022 | 07:55 AM
Du4's Avatar
Du4
I took it out Sunday morning. I found that the pin that holds the door was pulled out a little. I guess this happened at the car wash a while back. So I tapped in back and adjusted the spring and it's working fine. Thanks again for the help.
Old May 17, 2022 | 12:03 AM
gDMJoe's Avatar
Thumbs up
Du4 - I took it out Sunday morning. I found that the pin that holds the door was pulled out a little. I guess this happened at the car wash a while back. So I tapped in back and adjusted the spring and it's working fine. Thanks again for the help.
Thanks! for the follow-up.
