Ground Wire for Blower Motor on 2009 F150
I am having trouble with the blower motor not running on my 2009 Ford F150. I have replaced the blower motor resistor, the blower motor resistor connecter, and the blower motor. It has worked intermittently, but just for a short period of time. I am trying to locate where the ground wire for the blower motor connects to the body/frame.
The ground for the blower motor is switched through the blower speed control module (under the control of the DATC module) then goes to ground connection G203 which is somewhere around the base of the firewall above and behind the accelerator pedal to the right of where the steering shaft goes through the firewall.. Sorry, but the manual isn't any more clear than that.
