Transmission code P0016 on a 2011 F-150
Old Dec 11, 2020 | 09:37 PM
Keith Spikes's Avatar
What to replace when this code pops up on the check engine light. It seems to cause poor acceleration, especially when you going up a hill.
Old Dec 11, 2020 | 10:45 PM
https://www.autocodes.com/p0016_ford.html
Which engine? That's not a transmission code, it's an engine code.
Old Dec 12, 2020 | 06:57 PM
Thanks for viewing my message. My engine is 3.5L V6.
Old Dec 12, 2020 | 10:47 PM
gDMJoe's Avatar
Exclamation
Keith Spikes ...
HINT/TIP: Put your vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Edit Signature
Old Dec 29, 2020 | 12:05 AM
FixxerAuto's Avatar
Sounds like you may have a problem with your timing set. It may be that your chains have stretched or that your cam phaser is starting to get loose. This code is telling you that the bank 1 camshaft is out of sync with the crank shaft. While this could be a cam or crank sensor, in my experience, it is almost always the timing set.
