F-150 3.5 Ecoboost Gold Wrench light P2112 error code
1st thing in the morning, 2 days in a row, get 2 miles from home and the RPMs drop to 900 and the transmission drops to 1st gear. Accelerator pedal has no effect at all. Turn engine off/on and light goes out and drives normally. Naturally, the dealer can't duplicate the problem. Any ideas ?
What year?
Common Causes Of A P2112 Code
Possible causes of this code may include:
Faulty throttle body
Dirty throttle plate or linkage
Faulty throttle position sensor
Defective accelerator pedal position sensor
Throttle actuator control motor is defective
Corroded or damaged connector
Faulty or damaged wiring
Faulty PCM
Common Repairs
Replacing throttle body
Cleaning throttle plate and linkage
Replacing throttle position sensor
Replacing throttle actuator control motor
Replacing accelerator pedal position sensor
Cleaning corrosion from connectors
Repairing or replacing wiring
Flashing or replacing PCM
Read more at: https://www.obd-codes.com/p2112
Copyright OBD-Codes.com
Faulty PCM
Common Repairs
This may be irrelevent but Fast Lane Truck has a video of individual's long lasting trucks. One of the trucks with over 200k miles on it was an ecoboost. The owner said he had to replace the throttle body many times. Said it ate throttle bodies.
mrenberg ...
