High beams don’t work
Old 03-18-2019, 07:03 PM
JackDSmith's Avatar
High beams and indicator light works in the FTP position when u push control switch forward the high beams or the indicator does not work. All other lights work correctly. I have checked all fuses. Any ideas. 2009 f150 king ranch multipurpose stalk seems to go in high beam slot fine but high beams never come on. High beams work in flash to pass position fine along with high beam indicator light. Neither indicator light or high beams come on when multipurpose stalk is in the high beam position
Old 03-18-2019, 07:17 PM
First: What are you working on? We can't see it through the Internet...
Likely it's the Multifunction Stalk.
Also, the wording of your post is off... please use some better grammar. -- Thank you.
Old 03-18-2019, 08:30 PM
JackDSmith's Avatar
Malfunctioning high beam lights
2009 f150 king ranch. Low beam lights work fine. Fog lights work fine. Flash To Pass high beams work and high beam indicator light comes on in the Flash To Pass position. When multi function switch or blinker control is pushed forward neither the high beam indicator or the high beam lights come on. All fuses have been checked and swapped out. The blinker switche seams to feel fine when put in the high beam position
Old 03-18-2019, 08:44 PM
Old 03-18-2019, 11:50 PM
Threads have been merged. You will get more efficient help if we keep one thread per subject.
Quick Reply: High beams don’t work
