Vapor lock???
Vapor lock???
So I have a 2009 Ford F-150 stx four-wheel drive I was getting on the highway accelerating normally and my truck dies now I've been having issues with my fuel gauge recently we're fluctuates up and down so I assumed I was just out of gas had the girlfriend take me to get a gas can put gas in it and it re fired so I brought it to the gas station filled it up. That was the end of it but now it's died on me twice when I try to refire it cranks even when on accessory but if I go and open the easy Fuel fuel cap or whatever it's called it starts right back up any ideas?
I believe the fuel filter is internal but I will check the module excuse my Automotive ignorance but would I be able to tell without pulling the module off
I did check and change the module it was all black plastic so I couldn't tell if it was corroded or not so far so good it hasn't died since I drove it about 60 miles thank you for your advice so far I hope this fixes it
so where is doing that I would try to start it and it would just crank but then when I let off the key it would keep cranking until I turn the key all the way to the off position
I think I found the issue this is the number 27 fuse for the fuel pump relay
