Humming Nois
Old Feb 17, 2018 | 04:40 PM
plastic's Avatar
Humming Nois
I have a 2013 F150 4x4 with a 5.0 , when i drive i hear the humming, i jacked p the truck both sides and tried to shake the wheels, they would not move, i took the driver side tire off and turned the hub, thought i could feel a clicking in the hub, took the hub off and bearing feel out, I put a new hub on and drove it down the road, still there ! ....... should i replace the other hub ? ....... when i put the truck in 4 wheel drive the noise goes away ! ........... not sure what to check or look for any ideas Thanks
Humming Noise .....LOL
Old Feb 17, 2018 | 10:25 PM
Check your IWE.
Old Feb 18, 2018 | 07:37 AM
plastic's Avatar
Thank you
I am going to check it out !
Old Feb 18, 2018 | 06:45 PM
plastic's Avatar
Thank you very much for your help !
I went on line to see how to check out the wheel end ( lock )
I checked it out and sure enough the driver side was bad, I replaced it ! took about a hour and am all good !
Your help was very much appreciated
Old Feb 18, 2018 | 09:15 PM
No problem. Glad we were able to assist.
And by the way welcome!
